02-08. Save Defaults Settings in AutoPIPE
Comments, Questions, and Answers about Save Default Settings:
Item #1:
What start up settings can be customized to be automatically set when a new AutoPIPE model is created?
Item #2:
Is it possible to save Pipe IDs between AutoPIPE models?
Item #3:
Can I import combinations between AutoPIPE models?
Item #4:
Where does the default settings file get saved to?
Settings
