| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | May. 2017 11.00.00.22 |
Detailed information about "Flange Summary" sub-report from AutoPIPE
what does each of the columns mean?
What does each column from the Flange Analysis Summary sub report mean?
Point name = node point location of referenced flange
No. = multiple flanges can exist at the same node point, this value indicates which number of occurrence.
Flange Type = Displays the type of flange defined at that node point
Attachment = describes all of the possible attachments available for the different flange types
Analysis Method = Flange analysis has 4 different methods with which to analyze a flange. this indicates which of the 4 was used
Gasket Seating Bolt Load = the definition of the gasket seating bolt load, Wg, to be used in the flange analysis
Analysis = was a flange analysis actually performed.
If set to No, than Flange Analysis has not been performed.
If set to Yes, Flange Analysis has been performed and indicates if flange passed or failed.
Max Ratio = Displays the maximum ratio calculated during the analysis
Notes = Displays the number of warning and error messages if the analysis failed. If the analysis is successful, displays the condition and type of stress associated with the maximum ratio
"Flange Summary" sub-report results
