| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | April. 2018 11.02.00.10 |
when I look at the component data listing for an elbow the SIF are:
COMPONENT DATA (Bend, TIP= B03, Near= B03 N, Far= B03 F):
Long Elbow, Radius= 3.000 inch, Bend angle= 90.00 deg, End flanges= 1, Flex= Auto, SIFI= 1.47, SIFO= 1.23
However, when I review the Bend Data listing report sub section, the SIF values are:
Why are the SIF values different for the same elbow ?
The calculated SIF is affected by the pressure case setting used in the Load> Static Analysis set. In the above example, see that Pressure Case = P1. If Pressure Case = None the SIF values would match exactly with the value in the Component Data Listing sub-report as indicated below:
SIF values in Code Compliance report
