| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Report |
| Date Logged & Current Version | April. 2017 11.00.00.22 |
There seems to be a unit issue in the Results Summary Output Report (please see below). It is written "Stress [N/mm2]" although it is clear that Ring Deflection and Flotation are not stresses and are not measured in [N/mm2]. Please also check that the conversion form imperial to metric units in this Output Report are correct.
R E S U L T S U M M A R Y
Maximum HDPE Ring Deflection stress
Point : F00
Stress N/mm2 : 0.0
Allowable N/mm2 : 0.0
Ratio : 0.46
Load combination : Ring Defl-HDPE{1}
Maximum HDPE Flotation stress
Point : F00
Stress N/mm2 : 0.5
Allowable N/mm2 : 10.5
Ratio : 0.04
Load combination : Flotation-HDPE{1}
This is correct, ring deflection is in units of length only and flotation is in units of force/length.
"Result Summary" sub-report using Results> Output Report
