| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
What is the accuracy rating for results in AutoPIPE compared to hand calculated values?
Bentley AutoPIPE's accuracy has always been and will continue to be no more than 2.5% error.
As mentioned in our ATS documentation:
"The numerical results of the AutoPIPE Acceptance Test Set shall be within the acceptance criteria of nominally 2%, unless otherwise noted. Numerical results generated by other editions, or run under differing operating environments, are also expected to be within the same acceptance criteria (nominally 2%, unless otherwise noted). Therefore, edition specific output comparison files will not be provided."
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
