| Version(s): | 2004, XM, & V8i | ||
| Area: | Report | ||
How to differentiate the equipment load output are in global or local coordinates?
Use AutoPIPE online help for details on the results. When using the results grids, press the help button on the respective screen to see what the column information is pertaining too.
In addition, see Tools> Model Options> Force (Global/Local), see online help for for details on this option.
Results Post Processing in AutoPIPE
