Output Report - PlantFLOW
Comments, Questions, and Answers about PlantFLOW's output report
Item #1, Question
What gives the maximum effect on dynamic pressure shown in output report (gas system)? It seems it is the "Base" one (Standard conditions), why?
Answer: The dynamic pressure  is based on the actual fluid density and velocity upstream of the element.
