| Version(s): | ALL | ||
| Area: | Report | ||
The following are issues related to the Model Input listing "Load Case Description" sub-report in AutoPIPE:
How can I print the load case descriptions in my output report?
I see where I can enter the "Load Case Descriptions" under the Load menu. I also see under Tools>Combinations where I can input a description for each non-code case. I do not see where I can print these out for users of my reports to make use of my efforts naming everything.
Answer:
AutoPIPE V8i 09.06.xx.xx has an enhancement that allows the user to enter in a load case description. This description can be entered into 2 locations:
1. Load> Load Case Description...
2. Tools> Combinations> Code comb. and Non-code comb. tab at the far right of the grid enter in a description:
Each of these descriptions can be printed in the respective sub-reports.
1. Load Case Description... will be printed in the Tools> Model Input Listing> "Load Case Description" sub-report, toggle the check-box On / Off as needed.
2. Combination Descriptions...will be printed in the Results> Output Report> "Analysis Summary" sub-report toggle the check-box On / Off as needed.
Code Comb descriptions: "CODE COMPLIANCE COMBINATIONS" section
Non Code Comb descriptions: "NON-CODE COMBINATIONS" section.
Component Data Listing (Model Input Listing) FAQ
