| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Report | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
Can AutoPIPE print the Output reports to MS Excel, *.csv, or MS Word
AutoPIPE CONNECT 11.00.xx has a Technology Preview that users can test a small sample of exporting output reports to both MS Word and MS Excel. However AutoPIPE CONNECT 10.xx and lower cannot print its reports directly to MS word or MS Excel. Reports in the older versions are currently written to the following files: *.OUT, *.HGR, *.RPT. These file can be opened by any text editor (i.e. NotePad, Ms WORD, ect..) .
Also note, all versions of AutoPIPE can
a. export both the Input grids and Results grids to a database file (*.MDB), for manipulation into customized reports.
b. Copy / Paste Input grids and Results Grids to other applications, i.e. Ms Word, Ms Excel, for further interrogation / manipulation.
How to copy / export Input or Results grid data to MS Access / Excel:
Typical Comments, Questions, and Answers about Output Reports
