| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
Can we select a number of specific node points, pipe supports, etc. to report in the AutoPIPE result print out?
Using any of the various method of selection, select the node points, supports, bends, beams, etc. that are to be printed in the output report. After the selection process has been completed, perform a Model analysis as needed, and then selected Tools> Results> command.
On the Batch report dialog screen, enable the first option "Limit results to highlighted points", from the online help:
Use this option to limit the reported results to only points which are currently selected and thus highlighted on the screen.
Note: see the online help for complete details on this command.
Continue checking any additional feature on the dialog as necessary, and press the OK button. The output will display only those selected points in the respective sub-reports selected.
