| Product(s): | AutoPIPE | ||
| Version(s): | V8i, CONNECT; | ||
| Area: | Reports | ||
| Date Logged & Current Version | Oct. 2015 10.00.00.10 |
AutoPIPE result grids does not match the actual output reports, why?
Example:
When I open the result grid, displacements, the displacements do not match the displacements in the model. i.e. when I open Result -> Grids -> displacements these are not the same as: Result -> Displacement
There is a possibility of the grids data not matching the reported data due to the process of analyzing, closing the model, re-opening the model, and reviewing results.
The best approach is to delete the results before analyzing.
Under Analyze> select Delete Analysis Results...
Delete Analysis Results provides the opportunity to select all or individual analysis results to be deleted for the current model. After deleting analysis results, the default code and non-code combinations shall be automatically updated when "Auto" update is "on" for the code and non-code-combinations.
Finally, analyze the model and review the interactive and/or reported results.
