| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Import / Export | ||
| Date Logged & Current Version | April 2018 08.11.08.32 |
The following occurred when importing a file from AutoPIPE:
Warning
Please select a Allowable Year First
OK
This message is stating that the model does not know what allowable to calculate because there was no code year selected.
Update the code year by
a. Selecting System Tab
b. Press the "Y" button just to the right of Design Code setting
c. Select the drop down listing to choose a setting
d. Press OK to accept the year that will be used when calculating the code allowable.
