| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | March. 2018 11.02.00.10 |
What does D/A/P/C mean in the Code Compliance Combination report?
Look to the bottom of the page to the Notes for definition of each letter (see image above):
D/A/P/C: [D]efault / [A]uto-Update / [P]rint options / [C]Consistent (Y=Yes, N=No)
a. Default: set to Yes for all default combinations and set to NO for all user combinations
b. Auto-Update: set to Yes when Field is enabled and set to No when field is disabled
c. Print Options: set to Yes when Field is enabled and set to No when field is disabled
d. Consistent: set to Yes when combination is considered consistent and set to No when combination is considered to be in-consistent.
