| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Report | ||
| Date Logged & Current Version | Feb. 2016 10.00.00.10 | ||
Explain the Code Compliance settings in the Analysis Summary of AutoPIPE's output report, where are these settings adjusted
Most of the settings in this sub-report can be found in the following location of AutoPIPE, Tools> Model Options> Results
The following Dialog will appear. Changes to this dialog may significantly alter the results in AutoPIPE's output grids, reports, and exported MDB files. Be sure to read AutoPIPE's help to full understand each settings and their ramifications to the results.
See Results Model Options settings dialog and listing of Code Compliance Analysis Summary sub-report of settings
Question: What settings effects which summary statement? below:
Note: The above dialog and report are dependent on the Piping code selected in the model. Changing the code will make more or less settings appear or be grayed out, see AutoPIPE help for details.
Answer: see image below, click on the image below to zoom:
The following 2 settings are located in a different location, Tools> Combinations> Combination Options drop down listing, shown below:
"Analysis summary" sub-report using Results> Output Report in AutoPIPE
