| Applies To | ||
| Product(s): | AutoPIPE | |
| Version(s): | All | |
| Area: | Reports | |
| Original Author: | Bentley Technical Support Group | |
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
What does the [TR] mean in the code compliance report below:
ASME B31.3 (2006) CODE COMPLIANCE
(Moments in ft-lb , Force in lbf
Point Load Axial
name combination Force
A04 N+ Max P
GR + Max P 17003
TR:T2 to T3 2768
Amb to T1 1383
Amb to T2 367
Amb to T3 2401
T1 to T2 1750
T1 to T3 1018
T2 to T3 2768
What does TR: T2 to T3?
The TR is the In short, see AutoPIPE Tools> Model Options> Results> Intermediate stress points, refer to the online help fro details.
In the Code Compliance report, the Max Range combination is printed as "TR:"" followed by the thermal range that produces the maximum stress, e.g. "TR:T1-T3", where "TR:" is the abbreviation for (T)hermal (R)ange. Using the Max Range option provides the maximum stress range without printing the results for every thermal range combination explicitly.
The setting is controlled by Tools>Model Options> "Include Max Range comb". See the online help for full details on this setting. In addition, review the Tools> Model Options> "No. of thermal ranges" settings, again see the online help for details on this setting.
"Code Compliance" sub-report using Results> Output Report
