| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Reports |
| Date Logged & Current Version | Dec. 2016 10.01.00.09 |
Are the Forces and Moments report based on Global or local Coordinate system in AutoPIPE?
Create an output report printing the Forces and Moment sub-report. At the top of the page is information that tells the user what coordinate system is being used: Global or Local coordinate.
Note: Force and Moment coordinate system (Global/Local) is determined based on Force (Global/Local) option selected in the Results Model Options
