| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Import |
| Date Logged & Current Version | Dec. 2016 10.01.00.09 |
How to map segment name to an specific attribute using PCF translator in AutoPIPE?
Example: Map attribute "PIPELINEP-REFERENCE" to segment Line Number
First start by closing AutoPIPE and PCF translator
Next , manually open the PCFin.MAP file from the following folder location using any text editor (i.e. Ultra Edit, NotePad ++, MS Word, etc..):
%appdata%\ Bentley\PCF Translator\ PCFin.MAP
Than scroll (search) down the file until [SETTINGS], by default should be around line # 735.
Note that by default the "LINENUMBER" is set to "MISC-SPEC1"
Change this settings so "LINENUMBER" is now set to "PIPELINEP-REFERENCE"
Note: Maintain column alignment with the row above, PIPELINE... should start in column #18.
Save the file and close the PCFin.MAP file
Start PCF translator and import the PCF file. The segment Line number will now be shown correctly as shown above. .
Mapping examples from PCF translator
