| Product(s): | AutoPIPE | ||
| Version(s): | All | ||
| Area: | Import | ||
| Date Logged & Current Version | April. 2015 09.06.01.11 |
Following is displayed when trying to open converted PCF , NTL file in AutoPIPE:
"E880-1: Error in opening import batch file. File extension must be NTL".
There is a known issue if the file name has a blank space before the file extension, the above message is displayed. Confirm that the file name does not have a blank space before the file extension, example: "Test .NTL", remove space "Test.NTL"
PCF Translator FAQ & troubleshooting
