"Flange*" Messages displayed in AutoPIPE
The following messages appear when running AutoPIPE program:
Item #1:
"The value must be equal to the inside diameter of the pipe"
Item #2:
"The value must be equal to the outside diameter of the pipe"
Item #3:
"The value must be smaller than the outside diameter"
Also See:
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE
