AutoPIPE known issue - defect 748263
 Product:AutoPIPE
First Affected Version:10.01.00
 Found in Version:11.01.00.17
Fixed and Released in Version:11.01.00.23
 Area: All
 Severity: High
 Backlog Issue Number:748263
Behavior
• Severity: 1 - High
• First Affected Build: 10.01.00
• Affected Product: AutoPIPE
• Affected Versions: ALL
• Program Affected: Yes
• Program Help Affected: No
• Documentation Affected: No
Problem Description
For beam displacement calculations, Hydrotest is multiplying thermal anchor movements with temperature factor and then incorrectly adding them to thermal anchor movements again which gives incorrect displacement results for beams.
Steps to Repeat
1. Open attached archive model "hydrotest_temp_fact_TAM.APC"
2. Note that Pipe(A00 to A01) and Pipe design using beams (1001 to 1002) have same properties
3. Note both pipes have same thernal anchor movements of 1 inch in Z direction at point A00 and 1001
4. Analyse and go to results tab
5. Open interactive scan for displacement of thermal load case "Thermal{1}"
-Note that displacement results are not same. For beam point 1001 displacement is 2.25 whereas for piping point A00 its 1.25
Workaround
None
Since thermal anchor movements are already multiplied by temperature factor once, program should not add them again.
Also See:
Critical and High issues released in v.11.01.00
Known Issues in AutoPIPE (Enhancements, defects, etc..)
