Critical and High issues released in AutoPIPE CONNECT v.11.01.00
748263Hydrotest: For beams thermal anchor movements are multiplied with temperature factor and incorrectly added to thermal anchor movements for displacements
747811Imposed Support Displacements inserted on supports or anchors connected to beam members are not considered for Multiple Support Response Spectrum analysis
737822
702173ASME Nuclear: Incorrect density, composition, and modulus values for standard pipe materials NI and GROUP-1-B
702082
ASME NC/ND: Stress Summary calculations incorrectly uses branch pressure and geometry for pressure term calculations
673865ASME NB: Stress, allowable and SIF calculations for a reducer may use incorrect Pipe properties and Pressure/Temperature data
656782ASME NB: Changing fatigue curve for a pipe identifier may modify fatigue curves for other pipe
354776ASME NB: Tee moments may use incorrect sign and may lead to incorrect stress results when combining signed and unsigned combinations
Critical & High issues released in version
