| Version(s): | All | ||
| Area: | warning | ||
The following occurs when using AutoPIPE:
forrtl: severe (30): open failure, unit 6, file....OUT
How to resolve ?
The CAE development team was unable to reproduce this issue because the information in the Fortran run-time error image is not sufficient for us to diagnose the problem. We will still need the STEP - BY STEP procedure to repeat this problem and the model, if available.
The original occurrence of this issue was not resolved. The problem no longer occurred after updating to a newer version of the application.
Visual Fortran run-time error messages
