| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Readme | ||
| Date Logged & Current Version |
Mar. 2015 09.06.01.11 |
Product Name |
Bentley AutoPIPE V8i, released |
Version Number |
09.06.01.11 |
Application Group |
SELECT Released Products |
Language |
Spanish |
Solution |
Pipe Stress Analysis |
Operating Systems |
Windows 7 Windows 7 x64 Windows 8 Windows 8 x64 |
Dependencies: |
Structural Dashboard V8i - English 08.11.09.08 or higher Bentley IEG License Service - English 02.00.20.01 or higher
Note: Bentley IEG License Service is NOT required to run this AutoPIPE version.
Bentley AutoPIPE V8i is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 24 piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system..
This new release provides new features, critical code updates, and enhanced product interoperability. This is a maintenance release for AutoPIPE V8i (09.06.00.19) which includes several bug fixes plus the following new features
See the DETAILED Readme file (note: the read me file contains limited amount of data about errors / enhancements, only QA&R members have access to detailed information)
