| Product | Bentley AutoPIPE CONNECT |
| Version | 09.06.01.11 |
| Language | English |
| Date Posted | 12/16/2014 10:29:29 AM |
| Platforms | Microsoft Windows 7 Professional or higher Microsoft Windows 8 Professional or higher 32 or 64 bit OS |
Notes:
1. Bentley IEG License Service is NOT required to run this AutoPIPE version.
2. Must be a member of Bentley's AutoPIPE QA program to install and use ATS with this version.
Bentley AutoPIPE V8i is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 24 piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system..
This new release provides new features, critical code updates, and enhanced product interoperability. This is a maintenance release for AutoPIPE V8i (09.06.00.19) which includes several bug fixes plus the following new features
See the DETAILED Readme file (Note: the read me file contains limited amount of data about errors / enhancements, only QA&R members have access to detailed Error Reports)
See procedure for Installing AutoPIPE V8i 09.06.01.11 (different version but same process)
| Bentley ADLPipe to AutoPIPE Translator | 01.00.00.17 |
| Bentley AutoPIPE V8i Select Series | 09.06.00.15 |
| Bentley AutoPIPE Nozzle V8i | 08.11.08.23 |
| Bentley PCF to AutoPIPE Translator | 01.00.00.39 |
| Bentley STRAIT to AutoPIPE Translator | 06.00.00.14 |
| Bentley AutoPIPE Batch File Generator | 1.0.0.0 |
| AutoPIPE V8i SELECTseries 5 Setup | 09.06.01.11 |
AutoPIPE V8i Select Series 5 Release Notes (09.06.xx.xx)
