Platform: AutoPIPE is designed to run on the following platforms/operating systems. At a minimum, your computer should meet the minimum requirements for that system; for example, the amount of RAM required by AutoPIPE depends on the RAM requirements of the environment in which you will be working:
- Windows XP Professional SP2 or later OR
- Windows Vista Business or higher
- Windows 7 Professional or higher
Hard disk space: Approximately 250 MB
Graphics Card: OpenGL 3D graphics supported
Processor: Intel Pentium III or higher
RAM: minimum 256 MB
Web Browser: Microsoft Internet Explorer 6 or greater
Version
09.04.00.19 |
Build Type
SELECT Release Product
Operating
Systems |
Microsoft Windows (see System Requirements for specific details)
Language
English
Date
11/11/2011 |
|_autopipe
|_09040019en
|_install
|_Translators - This folder contains translator installers
Note: For further information on translators, please refer to their respective readme files.
Important Note: The following prerequisites are required to run each of the modules included within the application:
Processor
Intel Pentium III or higher |
Operating System
Microsoft Windows XP Professional SP3 or later OR Microsoft Windows Vista Business or higher Microsoft Windows 7 Professional or higher 32 or 64 bit OS
Web Browser
Memory
256MB
Hard Disk
250 MB minimum free hard disk space
Video Graphics Card
Any industry-standard video card which supports OpenGL 3D graphics
PDF Reader
Adobe® Acrobat Reader 7.0 or greater
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
To download the products, create a MySELECT CD or to complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles you will need to obtain the name of your Site Administrator from the Bentley website at SELECTservices Online at http://selectservices.bentley.com . Select MySupport Account / Permissions. Clicking on the List SELECTservices Administration button will access the Site Administrator at your company enabling you to request that the appropriate permissions be added to your profile.
With the appropriate privileges you can obtain the software as an electronic file from Web Downloads or the products may be ordered on a personal CD through MySELECT CD. Once you have installed the desired product you will need to complete the product authorization process by obtaining a license file from Bentley.
SELECT Services Online / MySELECT CD: When you order a custom CD from MySELECT CD the product directory structure for this product appears as shown. To install from the CD locate and run the setup.exe file and follow the online instructions.
The installation program will guide you through the process, prompting you for information when required.
If you are upgrading from an earlier version of the application, it is highly recommended that you do not install this product over the previous version.
Note: This is a standalone installation, no other previous installed product version is required.
|_autopipe
|_09040019en
|_install
|_setup.exe - This initiates the install process
Downloading the files from SELECT Services Online/Download - the download process gives you a choice to save the file to a specified location, or to begin the installation from the download area.
Network Considerations
Network drives are only supported for data files.
AutoPIPE software must be installed on a local client workstation.
AutoPIPE data files (*.DAT) must have full read/write access to be opened and edited.
Upgrading Your Current Product
AutoPIPE Standard, AutoPIPE Plus, AutoPIPE Nuclear, and add-ons are are all supported on the SELECT Server Licensing. If you are upgrading from an earlier version of the product, it is highly recommended that you do not install this product over the previous version. Older versions of AutoPIPE 6.3, 8.50, 8.51 and 8.60 will run under SELECT Server XM Licensing using the SELECT Server XM Gateway Service and the older SELECT licenses. For more information on the SELECT Server XM Gateway Service see the AutoPIPE Quickstart.pdf.
The AutoPIPE products can be authorized as Standalone Licenses (formerly called Fixed Licenses), fixed to one user workstation or as Concurrent Licenses (formerly known as Floating Licenses) running from a local or Bentley hosted SELECT Server.
Authorizing a Standalone License
If you are upgrading an existing installation to run on one workstation, and you have License Tool privileges you can obtain a license file to complete the authorization process. Access the License Tool at http://selectservices.bentley.com/ from My Support Account menu located on the left. Once you complete your request you will receive an email including a License File with instructions for completing the process.
Authorizing Concurrent Licenses to Run on SELECT Server
Concurrent Licenses (formerly known as Floating Licenses) are now managed through Bentley SELECT Server, a benefit of Bentley SELECT. Using SELECT Server requires a valid Bentley Serial Number, site server name and activation code to authorize the application. The Serial Number you received when you purchased the application is used to obtain a License File to complete the authorization process. For more licensing information see the AutoPIPE Quickstart.pdf.
Important: A signed SELECT agreement must be on file in order to convert your licenses from Floating Licensing to Concurrent Licensing.
Users who have existing Floating Licenses and wish to convert the licenses to run on SELECT Server can contact Bentley Sales Support Center from the website at http://www.bentley.com/en-US/Services/Bentley+Sales+Support.htm. The following information is required when requesting SELECT Server licensing: Server Name, email address of the recipient of the SELECT Server license and the Serial Numbers to be added to the server.
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader.
Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
The following is a list of new significant features and updates in Bentley AutoPIPE V8i (SELECTseries 3):
§ Retain inclusion of Cut short in analysis dialog
§ Add option to perform flange analysis to ASME VIII Division 1 or 2
§ Add Thermal Bowing by Segment
§ Provide option to create multiple analysis set for all piping codes
§ Create multiple analysis sets based on hot modulus for Euro Code by default
§ Option to calculate consistent sustained stress margin for B31.1, B31.3 & Euro
§ Add weight of insulation cladding to pipe
§ Implement an automatic soil property generator, per Appx B
§ Ability to perform simple design checks on the model
§ Add feature to automatically insert flanges with a flanged valve
§ Apply Fatigue Range Reduction Factor by material
§ Add option to graphically show Pipe Insulation
§ Input Grids for Static & Member Earthquake factors
§ Increase max number of flange/valve pres. ratings picked by program to 20
§ Option to include a factor of the flange weight for bolt/nut weight
§ Add an option to select connected segments
§ Option to display flanged flexible joint
§ Option to automatically insert flanges with a flanged flexible joint
§ Find a node based on entering coordinates
§ Add Valve Tag
§ Update distributed load data on insert/delete point(s) across distributed load.
§ Correct corrupted distributed loads in older models
§ Add a tag field to flange
§ Add a line class to pipe properties
§ Add Apply button in Soil Properties dialog
§ Default input grid to Press & Temp grid and reduce the horizontal slider
§ Allow reference point to be defined in any equipment dialog
§ View > Show thermal anchor displacement with imposed displacements
§ Improve performance of window selection operation
§ PXF Export should retain original supports class and properties as imported
§ Import GUID from NTL for piping, supports, beams etc
§ Add a dialog to link AutoPIPE components fields with pcf attributes
§ Export reference point loads to AP Nozzle
§ NTL: Add support for import/export of Time history data to NTL format
§ Import CAESAR v.5.3 neutral files
§ Add input grid for distributed loads
§ Add input grid for Reference node
§ Inadequate no# of significant digits for design strain on input grid
§ Input Grid: add Xtra data Hydrodynamic Data tab
§ Export JSM data, graphics and deflect plot
§ Add new valve type library for ball valve
§ Update Pipe Supports Spring Hanger (Comet) to match the updated catalog
§ Add an option to apply corrosion allowance to the Hoop stress only
§ Add Russian SNiP 2.05.06-85 Oil & gas code
§ Add back ASME B31.3 - 2004 into AutoPIPE V8i
§ Add B31.8 : 2010 code
§ Add B31.1 2010 edition
§ Enable circum. weld w factor for B31.3-2008 and B31.1-2009 codes
§ Add B31.3 : 2010 code
§ Add EN13480 : 2010 piping code update
§ Add manufacturer multiplier for NEMA SM23 and API 617
§ Preserve user descriptions for non-code combinations
§ Add option to hide non printed combinations on combinations dialog
§ Add a new option in result menu to show lift-off supports
§ Add option to import Combination CMB file information between models
§ Add center of gravity (COG) calculations for Structure & Piping
§ Allow print preview to work for LOG file to view nonlinear iterations
§ Add Flow Rate, Pressure Rise and Sound Speed to Fluid Transient report
§ Externalize stress iso data table titles and column titles to .tst file
§ Stress ISO: Create Bore equivalence file for nominal units mapping
§ Update to latest ISOGEN ver 10.3.0
§ Retain window/toolbar/file size/location settings in next program session
§ Reset window size and loc for input grid, results grid & APIPE viewer
§ Archive associated files with the AutoPIPE input file
§ RSS Feed: Show only recent news by default
§ Show thumbnail preview in open dialog and explorer
§ Increase number of string groups limit from 500 to 800 in autopipe.tst
§ Save as version 9.3 DAT files from 9.4
§ Program version and documentation updates
§ Update program title to SELECTseries 3
§ StressISO: Add an option to show/hide bend information.
§ Move MFC resources into a separate DLL
The following AutoPIPE features are considered as "Nuclear Safety Related":
The user document numbers which correspond to this release are:
DAA037360-1/0001 - "Tutorial"
The "Acceptance Test Set" document number which corresponds to this release is:
QA25API-9.4.0.19
Error reports are available with client participation in the "QA & Reporting" services. Please visit our Online Support login page at...
http://selectservices.bentley.com/en-US/
...in the Support Tools column near the bottom, select the 'AutoPIPE & STAAD.Pro Error Reports'. The requested User Name is your email address, and the Password is that which was previously assigned by your SELECTservices Site Administrator. Once you are successfully logged in, select the Link 'AutoPIPE & STAAD.Pro Published Errors'. This action will produce the 'AutoPIPE and STAAD Error Reports' page. Choosing the Error Reports tab will bring up a page that allows selection of the database for each major workgroup, and product Select 'Computer Aided Engineering', and the product you are interested in (the default is 'All Products'). Next, press the radio button for the 'Select a Time Frame" section. The two list boxes allow selection of the time period (month and year) and format style. Report type 'Simple' represents a summary set of information, where 'Complex' produces all publishable information related to the errors. The error reports can be printed directly as displayed, or they can be pasted into a word processor or spreadsheet program to allow custom formatting or permit word searching. Note that if the 'View Open Items' radio button is selected, a cumulative open error report will be generated.
Last Update: 2011/11/11
Revision: 0
© 2011 Bentley Systems, Inc. Legal Notice
U.S. Pat. Nos. 5,784,068 & 5,815,415 & 6,199,125
AutoPIPE V8i Select Series 3 Release Notes
