Civil Designers
This video series will help a new MicroStation user become familiar with the MicroStation CONNECT Edition.
This will be done from the point of view of a civil designer or drafter working at a design firm, who is new to MicroStation, and has been awarded a design project that they will be involved with.
During this course you will learn basic navigation of the MicroStation CONNECT user interface, creating and working with MicroStation design files, design file settings, and more.
If you are interested in trying out the exercises yourself, you can log into the Bentley LEARN Server and download the dataset. You will have to create a login if you don't already have one. Once you follow the link, look for the Dataset module and click Download. Chapters 1 through 10 use the same dataset, so you don't have to download it again if you've already done it for another chapter.
Parent topic: Role-Based Onboarding Experience
