Building Designers
This video series is an introduction to MicroStation CONNECT Edition for Building Designers.
This will be done from the point of view of a building designer or drafter working at a design firm, that is new to MicroStation, and has been awarded a design project that they will be involved with.
What's the difference between Building Designers and Civil Designers? In this video series, you will learn to create a Building Plan, based on a seed file provided by your company. You'll learn about general tools used in MicroStation, create interior and exterior walls, trim elements, create symbols called cells to use in your plan for furniture and other items, and so much more.
This 10-part series will walk you through the process from design to printed plans.
Interested in trying out the exercises yourself? Log into the Bentley LEARN Server and download the dataset. You will have to create a login if you don't already have one. Once you follow the link, look for the Dataset module and click Download.
Parent topic: Role-Based Onboarding Experience
