| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Analysis |
| Date Logged & Current Version | Nov. 2016 10.01.00.09 |
With the Bend Point dialog displayed, if one tries to press OK button the following error message is posted:
Error
E156-38: Value must be greater than zero.
OK
Why and how to fix it?
This message is posted when the piping code is set to ISO 14692 and the bend's Qualified Stress value is blank or set to 0.00.
Manually enter a valid value in the Qualified Stress field greater than 0.00 and then press OK button to close the dialog.
E2164-15: Qualified stress for all bend and tee components should be greater than zero
