| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Licensing |
| Date Logged & Current Version | Dec. 2017 11.01.00.23 |
How many sessions of AutoPIPE can I run at the same time on the same computer with only 1 license?
Can I open model A in session #1, and then open model B in another session of AutoPIPE on the same computer but only use 1 license?
When will a 2 license be used?
Bentley license usage is based on computer names. Therefore so long as the license is granted to use the 1st session of the program, user may open multiple sessions of the same program without concern of using more than 1 license count.
Again, Yes, user can open multiple sessions of AutoPIPE on the same computer under 1 license.
