| Product | Bentley AutoPIPE CONNECT |
| Version | 09.06.00.15 |
| Language | English |
| Date Posted | 10/04/2013 08:44:47AM |
| Platforms | Windows XP Professional or higher Windows Vista Professional or higher Windows Vista x64 Professional or higher Microsoft Windows 7 Professional or higher |
Note: Bentley IEG License Service is NOT required to run this AutoPIPE version.
Bentley AutoPIPE V8i is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 24 piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system.
Pipelink: Manage multiple structures in pipelink
Import displacement data from Excel
Import coordinate data from Excel, AutoCAD, and MicroStation
ISM / Hot Clash Z-Up to Y-Up Coordinate System transformation option
Interface with LISEGA LICAD pipe support software
PCF import, tolerance to join disconnected elements
Batch process multiple PCF files into one AutoPIPE model
New PCF setting to map North Axis to AutoPIPE global axis
Other New PCF import options
Rotate geometry, supports, static loads
Wave dialog graphics
Component weight e.g. clamp for spring hanger design
Ring Main Wizard (circular or polygon geometry)
New Wind Loading Dialog
Increase height-pressure data pairs for the wind profile to 10 or more
Program should support negative global directions (-X,-Y,-Z) in Wind Dialogs
Point coordinates in anchor results grid
Option to apply support stiffness per selected loadcase
DNV OS F101 : 2012 piping code
Update to B31.1 : 2012 piping code
B31.4 : 2009 and 2012 piping code
B31.8 : 2012 piping code
B31.3 : 2012 piping code
B31.3-2010 / 2012 : functionality for user to enter axial and torsional SIF
HDPE Plastic piping code - Code Case N755
Update to KHK : 2006 allowables
Cold Hanger design including spring variability by each spring
New Time history Load processor - displacement results by time step
Time history modal results to MOD file
Regional seismic load generators (Response spectrum and static g)
ASCE 2002 and 2010 Wind load codes
Snow Loading
Duplicate operating Cases
Define and view load case description
Activate Damper support for SAM cases for KHK-2 code
New Table of contents for all output reports
Update model consistency report to group similar warnings/errors
BHEL Spring Catalog
PSS Spring Manufacturer (Germany / UK Vendor)
WookWang Spring Catalog
See procedure for Installing AutoPIPE V8i 09.06.00.15
| Bentley ADLPipe to AutoPIPE Translator | 01.00.00.15 |
| Bentley AutoPIPE V8i Select Series | 09.06.00.15 |
| Bentley AutoPIPE Nozzle V8i | 08.11.08.20 |
| Bentley PCF to AutoPIPE Translator | 01.00.00.35 |
| Bentley STRAIT to AutoPIPE Translator | 06.00.00.13 |
Version
09.06.00.15 |
Build Type
Select Release Product
Operating
Systems |
Microsoft Windows (see System Requirements for specific details)
Language
English
Date
9/23/2013 |
|_autopipe
|_09060015en
|_install
|_Translators - This folder contains translator installers
Processor
Intel Pentium III or higher |
Operating System
Microsoft Windows XP Professional SP3 or later OR Microsoft Windows Vista Business or higher Microsoft Windows 7 Professional or higher 32 or 64 bit OS
Web Browser
Microsoft Internet Explorer 6 or greater
Memory
512 MB
Hard Disk
500 MB minimum free hard disk space
Video Graphics Card
Any industry-standard video card which supports OpenGL 3D graphics
PDF Reader
Adobe® Acrobat Reader 7.0 or greater
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
To download the products, create a MySELECT CD or to complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles you will need to obtain the name of your Site Administrator from the Bentley website at SELECTservices Online at http://selectservices.bentley.com . Select MySupport Account / Permissions. Clicking on the List SELECTservices Administration button will access the Site Administrator at your company enabling you to request that the appropriate permissions be added to your profile.
With the appropriate privileges you can obtain the software as an electronic file from Web Downloads or the products may be ordered on a personal CD through MySELECT CD. Once you have installed the desired product you will need to complete the product authorization process by obtaining a license file from Bentley.
SELECT Services Online / MySELECT CD: When you order a custom CD from MySELECT CD the product directory structure for this product appears as shown. To install from the CD locate and run the setup.exe file and follow the online instructions.
The installation program will guide you through the process, prompting you for information when required.
If you are upgrading from an earlier version of the application, it is highly recommended that you do not install this product over the previous version.
|_autopipe
|_09060015en
|_install
|_setup.exe - This initiates the install process
Downloading the files from SELECT Services Online/Download - the download process gives you a choice to save the file to a specified location, or to begin the installation from the download area.
Network Considerations
Network drives are only supported for data files.
AutoPIPE software must be installed on a local client workstation.
AutoPIPE data files (*.DAT) must have full read/write access to be opened and edited.
Upgrading Your Current Product
AutoPIPE Standard, AutoPIPE Advanced, AutoPIPE Nuclear, and add-ons are are all supported on the SELECT Server Licensing. If you are upgrading from an earlier version of the product, it is highly recommended that you do not install this product over the previous version. Older versions of AutoPIPE 6.3, 8.50, 8.51 and 8.60 will run under SELECT Server XM Licensing using the SELECT Server XM Gateway Service and the older SELECT licenses. For more information on the SELECT Server XM Gateway Service see the AutoPIPE Quickstart.pdf.
The AutoPIPE products can be authorized as Standalone Licenses (formerly called Fixed Licenses), fixed to one user workstation or as Concurrent Licenses (formerly known as Floating Licenses) running from a local or Bentley hosted SELECT Server.
Authorizing a Standalone License
If you are upgrading an existing installation to run on one workstation, and you have License Tool privileges you can obtain a license file to complete the authorization process. Access the License Tool at http://selectservices.bentley.com/ from My Support Account menu located on the left. Once you complete your request you will receive an email including a License File with instructions for completing the process.
Authorizing Concurrent Licenses to Run on SELECT Server
Concurrent Licenses (formerly known as Floating Licenses) are now managed through Bentley SELECT Server, a benefit of Bentley SELECT. Using SELECT Server requires a valid Bentley Serial Number, site server name and activation code to authorize the application. The Serial Number you received when you purchased the application is used to obtain a License File to complete the authorization process. For more licensing information see the AutoPIPE Quickstart.pdf.
Important: A signed SELECT agreement must be on file in order to convert your licenses from Floating Licensing to Concurrent Licensing.
Users who have existing Floating Licenses and wish to convert the licenses to run on SELECT Server can contact Bentley Sales Support Center from the website at http://www.bentley.com/en-US/Services/Bentley+Sales+Support.htm. The following information is required when requesting SELECT Server licensing: Server Name, email address of the recipient of the SELECT Server license and the Serial Numbers to be added to the server.
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader.
Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
The following is a list of new significant features and updates in Bentley AutoPIPE V8i (SELECTseries 5) :
§ Cold Hanger design including spring variability by each spring
§ New Time history Load processor - displacement results by time step
§ Time history modal results to MOD file
§ Regional seismic load generators (Response spectrum and static g)
§ ASCE 2002 and 2010 Wind load codes
§ Snow Loading
§ Duplicate operating Cases
§ Define and view load case description
§ Activate Damper support for SAM cases for KHK-2 code
§ Batch processing support for Thermal Transient Anlysis using command line
§ Batch option to export input MDB file
§ Batch option to hide the program screen during batch processing
§ New Batch Processing Utility
§ Batch switch /k to export model as NTL
§ Insulation, pipe density and specific gravity to view/show pipe properties
§ Color plot for Beam Sections
§ Display north arrow on graphical plot
§ Display of water surface and seabed levels
§ Option to use the Autopipe defaults file when importing NTL files
§ Interface with LISEGA LICAD pipe support software
§ PCF import, tolerance to join disconnected elements
§ Batch process multiple PCF files into one AutoPIPE model
§ New PCF setting to map North Axis to AutoPIPE global axis
§ PCF Translator to ignore duplicate components
§ PCF Translator to ignore continuation components
§ PCF Translator to ignore overlapping components
§ PCF Translator to detect and block importing overlapping components
§ PCF Translator to remove overlapping components
§ NTL Import to detect and blocked closed loop
§ PXF Import: Review linelist pressure/temperature data
§ PXF Import : Transform Z to X axis
§ PCF Translator: Fetch material from Item Code > Description
§ PCF Translator: Add new piping codes, Material and Component libraries
§ PCF Translator: Move Toler., flange length, Ignore options to Tools>Setting dlg
§ Pipelink: Manage multiple structures in pipelink
§ Import displacement data from Excel
§ Import coordinate data from Excel, AutoCAD, and MicroStation
§ ISM / Hot Clash Z-Up to Y-Up Coordinate System transformation option
§ BHEL Spring Catalog
§ PSS Spring Manufacturer (Germany / UK Vendor)
§ WookWang Spring Catalog
§ Rotate geometry, supports, static loads
§ Wave dialog graphics
§ Component weight e.g. clamp for spring hanger design
§ Ring Main Wizard (circular or polygon geometry)
§ New Wind Loading Dialog
§ Increase height-pressure data pairs for the wind profile to 10 or more
§ Program should support negative global directions (-X,-Y,-Z) in Wind Dialogs
§ Point coordinates in anchor results grid
§ Option to apply support stiffness per selected loadcase
§ DNV OS F101 : 2012 piping code
§ Update to B31.1 : 2012 piping code
§ B31.4 : 2009 and 2012 piping code
§ B31.8 : 2012 piping code
§ B31.3 : 2012 piping code
§ B31.3-2010 / 2012 : functionality for user to enter axial and torsional SIF
§ HDPE Plastic piping code - Code Case N755
§ Update to KHK : 2006 allowables
§ Update Result grids to use model result options > digits after decimal setting
§ New Table of contents for all output reports
§ Update model consistency report to group similar warnings/errors
§ Option to print acceleration report in G's values
§ Print total number of analysis points in the system in a report
§ Harmonic and Response Spectrum Load Type to Output
§ Provide option to print report headers on first page of report only
§ Stress ISO: Show Center of Gravity table on exported drawing
The following AutoPIPE features are considered as "Nuclear Safety Related":
The user document numbers which correspond to this release are:
DAA037360-1/0001 - "Tutorial"
The "Acceptance Test Set" document number which corresponds to this release is:
QA25API-9.6.0
Error reports are available with client participation in the "QA & Reporting" services. Please visit our Online Support login page at...
http://selectservices.bentley.com/en-US/
...in the Support Tools column near the bottom, select the 'AutoPIPE & STAAD.Pro Error Reports'. The requested User Name is your email address, and the Password is that which was previously assigned by your SELECTservices Site Administrator. Once you are successfully logged in, select the Link 'AutoPIPE & STAAD.Pro Published Errors'. This action will produce the 'AutoPIPE and STAAD Error Reports' page. Choosing the Error Reports tab will bring up a page that allows selection of the database for each major workgroup, and product Select 'Computer Aided Engineering', and the product you are interested in (the default is 'All Products'). Next, press the radio button for the 'Select a Time Frame" section. The two list boxes allow selection of the time period (month and year) and format style. Report type 'Simple' represents a summary set of information, where 'Complex' produces all publishable information related to the errors. The error reports can be printed directly as displayed, or they can be pasted into a word processor or spreadsheet program to allow custom formatting or permit word searching. Note that if the 'View Open Items' radio button is selected, a cumulative open error report will be generated.
Last Update: 2013/9/23
Revision: 0
© 2013 Bentley Systems, Inc. Legal Notice
U.S. Pat. Nos. 5,784,068 & 5,815,415 & 6,199,125
AutoPIPE V8i Select Series 5 Release Notes (09.06.xx.xx)
