| Product(s): | AutoPIPE Nozzle | ||
| Version(s): | V8i | ||
| Area: | Import | ||
| Date Logged & Current Version | June 2015 08.11.08.23 | ||
The following is displayed when importing a model into AutoPIPE Nozzle:
It is seemingly at random, independent of whether a .UCB file exists in the working folder, or whether a user load combination has been specified.
Why and how to avoid it?
This is going to be a tough one to resolve unless there are exact steps to repeat. At the moment there is no way of importing the user load combinations into AutoPIPE Nozzle as the program itself creates a *.UCB file when User Load Combinations are created with in the program.
If for some reason the *.UCB file was removed from the folder where the model (*.NOZ) file is located, then, Yes, when opening the *.NOZ file in AutoPIPE Nozzle the warning above will appear. Again, the UCB file is only created in the same folder when user combinations have been specified, and the model has been saved.
If the warning message continues to display with all the files intact, please send exact steps to repeat and a ZIP file containing all the files in the folder to Bentley for review.
Warnings Messages displayed in AutoPIPE
