The following enhancements and defects have already been requested:
Description:
Add the 2013 edition of GOST 32388: Process piping. Standard for the stress, vibration and seismic analysis, into AutoPIPE
Bentley AutoPIPE V8i v9.5 which includes the latest Russian SNIP 2.05.06-85 for design of above and underground Oil and Gas pipelines has successfully been certified as meeting the Russian GOST standard. AutoPIPE has also been GOST certified as compliant with the following Russian standards:
a. SNIP 2.05.06-85 - Main pipelines
b. SNIP 2.04.12-86 - Steel pipelines of water supply and the water drain.
c. SP34-116-97 Designing, construction and reconstruction oil-and-gas pipelines
d. CA 03-003-07 - Technological pipelines pressure less than 10 MPa
e. PTM 38.001-94 - Pipelines at pressures greater than 10 to 100 MPa
f. CH 550-82 - technological pipelines from plastic
g. BH 39-1.9-005-98 - Sea, coastal pipelines.
h. RD10-249-98 - pipelines of steam and hot water.
i. RD10-400-01 - pipelines of thermal networks.
j. RD PTM26-01-44-78 - Technological pipelines pressure more than 10 Mpa
Development Project: TBD
Additional Information:
The calculations for GOST 32388 are essentially the same as ASME B31.3. The CAE development team has obtained certifications from a Russian authority that mentions AutoPIPE's B31.3 calculations meet the requirements for 32388. Again, that means the result of analyses in AutoPIPE corresponds to the GOST 32388-2013.
GOST 32388-2013: Process pipes (ASME B31.3)
GOST RD 10-249-98: Power Piping (ASME B31.1)
The CAE development team has these certificates available upon request, please log a service request mentioning this WIKI page
Piping Codes Enhancements & Defects
