| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | Sept. 2017 11.01.00.17 |
Why does additional weight not considered in my analysis?
In order to verify if a weight is being considered in the analysis, please review the following:
1. Model Input listing:
a. Extended Component report - search for the weight to confirm the settings
Example:
b. Center of Gravity - review report for additional weight that is considered for the analysis.
Example:
2. Input grids - review each tab that has a "Weight" column and determine if the settings are correct.
Example:
In the example above, it can be seen that there are no weight added from:
a. Contents - specific gravity of contents = 0.00
b. Weight of supports - weight values were blank
c Defined weight - weight value was blank
Update one or more of the settings mentioned above with a value greater than 0.00
Model Concentrated Forces / Added Weight
