| Product(s): | AutoPIPE Vessel | ||
| Version(s): | CONNECT | ||
| Area: | Installation | ||
| Date Logged & Current Version |
Dec. 2015 40.00.00.17 |
CONNECT Edition (40.00.00.17:2015-12)
The following outline identifies new features and enhancements in the CONNECT Edition of AutoPIPE Vessel 40.00.00.17.
Technology Previews provide users preliminary access to features currently in development but not yet ready for production. These features are provided at no additional charge to promote awareness of a feature or technology to be deployed in a future release. Users are encouraged to provide feedback and suggestions. To learn more about Technology Previews or to gain access, please create a Service Request (be sure to include "Technology Preview" in the Description field).
Product: AutoPIPE Vessel
Version: 40.00.00.11
Language: English
CD drive or access to the Internet required for product installation. The minimum system configuration for installation:
Operating System: 32 or 64 bit OS
* For x64 operating systems you must install the accessdatabaseengine x64 which Microsoft delivers with Office 2010. You can download this from Microsoft's website.
When installing the product through the installer program, the required components will be installed automatically. If, however, you extract the package and then later run the EasyMultiInstall.vbs or the msi file to install the product, the Desktop Prerequisite Pack 08.11.09.xx must be installed on your workstation prior to the product installation. The RealDwg2012.msi should be installed after the product is installed. The Desktop Prerequisite Pack is available from the Web downloads/MySELECT CD area of SELECTservices Online. The contents of the Desktop Prerequisite Pack include:
* RealDWG 2012 is required by some features and must be installed. RealDWG 2013 is not supported in this release.
The minimum recommended workstation profile for running AutoPIPE Vessel is:
Processor
Intel® or AMD® processor 3.0 GHz or greater.
Memory
256 megabytes (Mb) of free (1) RAM minimum, 4096 Mb or more is preferred. AutoPIPE Vessel will utilize all available RAM. AutoPIPE Vessel performance is dependent on the size of the AutoPIPE Vessel model and the amount of available system resources.
(1) Free RAM refers to available RAM after all operating system processes have been loaded.
Hard Disk
600 MB free disk space.
Video Graphics Card
Any industry-standard video card which supports OpenGL 3D graphics.
Screen resolution of 1280x1024 or greater.
CAD
MicroStation PowerProduct
AutoCAD x32 versions: 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
AutoCAD x64 versions: 2010, 2011, 2012, 2013, 2014, 2015, 2016
SolidWorks x32 versions: 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014
SolidWorks x64 versions: 2010, 2011, 2012, 2013, 2014
ProjectWise
ProjectWise Server 8.11.7 with ProjectWise Explorer 8.11.7.133 or higher, ProjectWise Server 8.11.9 with ProjectWise Explorer 8.11.9, ProjectWise Server 8.11.11 with ProjectWise Explorer 8.11.11.
Adobe PDF Reader
To view, print, and save PDF files, Bentley recommends Adobe Reader 10 or higher.
To download the products, create a MySELECT CD or to complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to obtain the name of your Site Administrator by submitting a Service Request at http://appsnet.bentley.com/srmanager/addcall.aspx.
If you are experiencing problems logging into your Bentley account, please contact bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
See the AutoPIPE Vessel Quick Start Guide for more information on downloading and installing AutoPIPE Vessel.
AutoPIPE Vessel is installed from one executable. The configuration of AutoPIPE Vessel includes these features:
| Design Code | Description | Editions |
| AD/AD 2000-Merkblatt | Code for Pressure Vessels (German Code) | 2012-07, 2011-05, 2007-11, 2007-05, 2004-10, 2003-01, 2000-00, 1996-08, 1995-07, 1995-05, 1993-04, 1991-10, 1990-10 |
| API 650 | Welded Tanks for Oil Storage | 2013-03, 2011-09 |
| ASME VIII Division 1 | Rules for Construction of Pressure Vessels | 2013-07, 2011-07, 2010-07, 2009-07, 2008-07, 2006-07, 2005-07, 2004-07, 2003-09, 2002-07, 2001-07, 2000-07, 1999-07, 1998-07 |
| ASME VIII Division 2 | Rules for Construction of Pressure Vessels (Alternatives Rules) | 2013-07, 2011-07, 2010-07, 2009-07 |
| BS/PD 5500 | Specification for Unfired Fusion Welded Vessels (British Standard Institute) | 2013-09, 2012-09, 2012-06, 2011-09, 2011-01, 2008-01, 2006-09, 2005-11, 2004-09, 2004-03, 2002-08, 2002-04, 2001-01, 1999-11, 1999-01, 1998-01, 1997-01 |
| CODAP | Code for Construction of Unfired Pressure Vessels (French Code) | 2012-10, 2011-03, 2010-11, 2009-03, 2007-09, 2006-06, 2004-12, 2004-04, 2002-12, 2000-12, 1998-12 |
| EN 13455 | Unfired Pressure Vessels (European Standard) | 2013-07, 2011-07, 2009-07, 2007-04, 2004-11, 2004-02, 2002-05 |
| GOST R 52857 | Vessels And Apparatus (Russian Code) | 2012-01, 2008-01 |
| NFE 32 100-108 | French Code For Construction Of Steam Generators | 1988-12 |
| EJMA | Standards of the Expansion Joint Manufacturers Association | 2008 (9th Edition), 1999 (8th Edition), 1993 (6th Edition) |
| TEMA | Standards of the Tubular Exchanger Manufacturers Association | 2007-11 (9th Edition), 1999-06 (8th Edition), 1997-12 (7th Edition), 1991-08 (7th Edition) |
| AD-Merkblatter S3/0 | General Verification Of Stability For Pressure Vessels | 1991 |
| ASCE 7 | Minimum Design Loads for Buildings and Other Structures | 2010, 2005, 2002, 1998, 1995, 1993 |
| British Standard BS 6399 Part 2 | British Standard for Loading for Buildings - Code of Practice for Wind Loads | 1997 |
| British Standard CP3 Part 2 | British Standard for Wind Loads | 1972 |
| EN 1991-1-4 | Eurocode 1: Actions on Structures - Wind Actions | 2005 |
| GOST R 51273-99 | Vessels and Apparatus NORMS AND METHODS OF STRENGTH CALCULATIONS Rated Strength | 2000 |
| IBC (ASCE) | International Building Code | 2012, 2006 |
| Indian Standard IS:875 Part 3 | Indian Standard - Wind Loads on Buildings and Structures | 1987 |
| NBC Canada | National Building Code of Canada | 2005 |
| NBR 6123 | Brazilian Code - Wind Load | 1998 |
| Neige et Vent 65 | French Wind Code | 1999, 1995, 1990 |
| Portuguese DL 235/83 | Portuguese Wind Code | 1983 |
| Spanish Code NBE AE 88 | Spanish Wind Code | 1988 |
| Uniform Building Code | US Code Until 1997 | 1997, 1994, 1991, 1988, 1982, 1976 |
| ANSI A58.1 | Minimum Design Loads for Buildings and Other Structures | 1982 |
| ASCE 7 | Minimum Design Loads for Buildings and Other Structures | 2010, 2005, 2002, 1998, 1994, 1993 |
| DIN 4149 | German Earthquake Standard | 2005-04, 1981 |
| EN 1998-1 | Eurocode 8: Design of Structures for Earthquake Resistance | 2002 |
| GOST R 51273-99 | Vessels and Apparatus NORMS AND METHODS OF STRENGTH CALCULATIONS Rated Strength Calculation of Column Type Apparatus from Wind Loads and Seismic Influence | 2002 |
| Indian Standard IS:1893 | Indian Standard | 2005, 2002, 1996, 1984 |
| Parasismique PS 92 | French Standard | 1995 |
| Parasismique PS 69 | French Standard | 1984 |
| Portuguese Earthquake LNEC | Hazard Analysis and Seismic Risk Assessment in Portugal | 1987 |
| Spanish Code NCSE-02 | Spanish Seismic Code | 2002 |
| Uniform Building Code | US Code Until 1997 | 1997, 1994, 1991 |
| EN 13445 | Par. 16.4 and 16.5 Local Loads on Nozzles in Spherical Shells / in Cylindrical Shells | 2013-07, 2011-07, 2009-07, 2007-04, 2004-11, 2004-02, 2002-053 |
| GOST R 52857 | Par. 6 Strength Calculation of Cylindrical Shells and Spherical Bottoms Under External Static Loads on the Nozzle | 2008-01 |
| PD 5500 G2 | Par. G.2 Local Loads on Pressure Vessel Shells | 2013-09, 2012-09, 2012-06, 2011-09, 2011-01, 2008-01, 2006-09, 2005-11, 2004-09, 2004-03, 2002-08, 2002-04, 2001-01 |
| PD 5500 G.2.8 | Par. G.2.8 Alternative Rules for Local Loads on Circular Nozzles in Spherical and Cylindrical Shells | 2013-09, 2012-09, 2012-06, 2011-09, 2011-01, 2008-01, 2006-09, 2005-11, 2004-09, 2004-03, 2002-08, 2002-04, 2001-01 |
| WRC B 107 + 297 | Local Stresses In Spherical And Cylindrical Shells Due To External Loadings | 2002-10, 1979-03 |
Product activation is achieved by connecting to a SELECT Server, receiving a verification that your SELECT Server Name and Activation Key are correct, and successfully posting Usage logs. Product activation is not the same as checking out a license. This document describes how to configure AutoPIPE Vessel for activation. After initial configuration, AutoPIPE Vessel automatically and transparently tries to activate each time it runs, and runs unconstrained for a period of 30 days after its last successful activation. However, if activation is unsuccessful for a period of 30 days, AutoPIPE Vessel will not start until it is activated again.
The Product Activation Wizard is designed to step users through the product activation process. After a product is installed, you must obtain a license and then activate that license. Obtaining the license alone is not enough to complete the process. This wizard eliminates the confusion and makes it clear that obtaining a license and activating a product are two essential steps.
The Product Activation Wizard opens automatically (unless the "Activate product using Bentley License Tool" check box is turned off) at the end of the product installation process. See the AutoPIPE Vessel Quick Start Guide for more information on installing AutoPIPE Vessel.
The first screen of the Product Activation Wizard offers four product activation options:
The wizard steps you through the activation process based on the options selected.
If you are activating against a local SELECT Server, you must provide the proper Server Name and Activation Key. The Server Name and Activation Key, along with any proxy configuration information, can be obtained from your Site Administrator.
If you are activating against a hosted (Bentley) SELECT Server, the Server Name is pre-populated but you must provide the proper Activation Key provided by the Bentley Sales Support Center.
If you are not a Bentley SELECT subscriber and you are activating AutoPIPE Vessel, you are presented with three options:
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2015, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "AutoPIPE Vessel" folder of the product installation. By default, this location is "C:\Program Files\Bentley\Engineering\AutoPIPE Vessel."
685 Stockton Drive
Exton, PA 19341-0678 USA
Phone: (1) 610 458-5000
FAX: (1) 610 458-1060
WWW: http://www.bentley.com/
Bentley Systems Europe B.V.
Wegalaan 2
2132 JC Hoofddorp
THE NETHERLANDS
Phone: (31) 23 556 0560
FAX: (31) 23 556 0565
WWW: http://www.bentley.com/nl-NL/
Bentley Engineering Software Systems
Unit 1402-06, Tower 1
China Central Place, Beijing 100022
CHINA
Phone: (86) 10 5929 7000
FAX: (86) 10 5929 7001
WWW: http://www.bentley.com/zh-CN/
How do I install and license AutoPIPE Vessel 40.00.00.11?
Readme Release Notes for AutoPIPE Vessel
