Bentley AutoPIPE Vessel V8i v.33.02.01.08 Software Release Notes
The following Release Notes are provided as a reference by Bentley's Technical Support Group.
 Version Number:         33.02.01.08
 Date Posted:               4/1/2014 11:56:13 AM
 Application Group:      SELECT Released Products
 Language:                  English
 Operating Systems:
Windows XP
Windows Vista
Windows Vista x64
Windows XP x64
Windows 7
Windows 7 x64
Description
Bentley AutoPIPE Vessel V8i is a stand-alone, Engineering application for the comprehensive calculation of pressure vessels, heat exchangers, tanks, and air coolers to ASME, European, French CODAP, German ADM,and Russian GOST standards. It is the only program to perform truly optimized vessel design in minutes and produce fully automated detailed drawings and cost estimates.
This is maintenance release 2 for AutoPIPE Vessel V8i which includes several bug fixes, cost estimate in U.S. units plus the following new features including the latest ASME 2013 code update and support for Solidworks 2011 to 2014 from maintenance release 1.
Design Codes
Full list of Enhancements and Defects
Enhancements
Defects
AutoPIPE Vessel Readme - download here
Download, Install, and License AutoPIPE Vessel:
The following procedure is perfectly suited for installing the newer version, only change being the version of the software being downloaded should be 33.02.01.08:
How do I download, install, and license AutoPIPE Vessel 33.02.00.06 on Win 7
Limitations:
This version is supported on AutoCAD 2014 and lower
Product Technotes & FAQs
