| Version(s): | V8i | ||
| Area: | Enhancements | ||
| Subarea: | |||
A. Import coordinate data from Excel, AutoCAD, and MicroStation
B. Hot Clash detection ISM / Hot Clash Z-Up to Y-Up Coordinate System transformation option
C. Import Impose Support Displacement from MS Excel file
D. Import multiple STAAD Structures into the same AutoPIPE model
E. Create a Ring main (Circular Header)
F. STAAD to AutoPIPE Integration
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
