"EN-1991" Piping Code Enhancements & Defects for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
TFS-E100922:
Add European Wind Codes (EN 1991-1-4, EN 1998-1 and EN 1991-1-3)
Description:
Occasional loads, like wind, seismic and snow, but especially wind, have mostly been based on American standards (like ASCE), which makes it hard for European work to accurate model wind loads.
Suggestion to include an option in AutoPIPE, to define occ. loads (like wind, seismic and snow) based on relevant EN standards (EN 1991-1-4, EN 1998-1 and EN 1991-1-3, respectively), using also the national annexes. This way, the user only has to select the region the piping system is in, and AutoPIPE can apply the local values for occ loads (based on national annexes), and relevant calculation methods (EN 199x-series standards).
Piping Codes Enhancements & Defects
