Q. Can AutoPIPE TTA be used to analyze a Pipeline caring steam?
Question:
Answer:
Unfortunately, the AutoPIPE TTA module does not consider steam as a content for evaluation as an input. Further, the calculation will continue to consider the fluid as water or heavy water regardless of the temperature and pressure, even if the saturation limit is exceeded.
A new IDEA has been logged here. Add your vote to this IDEA to help push this new feature into AutoPIPE and to be kept informed of the feature status.
"Thermal Transient Analysis" (TTA) - AutoPIPE Load Case
