AutoPIPE V8i 09.05.01.05 |
139027 |
Incorrect mapping of support groups when changing JSME edition from 2008 to 2005 |
139025 |
Incorrect SAM displacements for JSME 2008 with more than 2 support groups |
138889 |
Sustained Allowable may be incorrect for NS & Materials for B31.3/B31.1 code |
AutoPIPE V8i 09.05.01.02 |
138814 |
FlangeAnalysis: Bolt Spacing Correction Factor may calculate incorrectly |
138810 |
Sustained allowable for B31.1 & B31.3 may be incorrect when Circ. W fac. applied |
138808 |
B31.3-2010 Occasional allowable may be unconservative for T<Tcr or Tcr=0 |
138778 |
Program not reporting max stress from -ve and +ve faces of soil and kink points |
138755 |
SAM axial stress of plus face of a point uses axial force of minus face |
138754 |
Bend near point does not use SIF value for Adams Method ASME NC/ND |
138694 |
Creep for 1.49XX material in EURO2009 using incorrect data from German version |
AutoPIPE V8i 09.05.00.21 |
138656 |
The allowable (K) factor does not reset after changing the stress category |
138342 |
Ke is less than 1 when service level Rupture is selected and 2.4 Sm < Sn < 3 Sm |
138308 |
American materials in EN13480 library may have incorrect creep data |
138271 |
Two flanges added to a component may incorrectly share the same flange data |
138250 |
BTP 1987 Rupture limit for equation 9 is using min. hot Sy instead of design Sy |
138165 |
Minimum allowable is not used for tee stresses in JSME |
Critical and High issues released in version
