| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | Aug. 2017 11.01.00.17 |
Can load variation be set to a different value, why does AutoPIPE default to 25% in spring hanger selection?
Based on information from spring manufactures, the industry standard maximum recommended value for Load Variation is typically 25% for a variable spring hanger. Where the actual value for a spring support may be less than the 25% maximum.
