| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Analysis |
| Date Logged & Current Version | June. 2017 11.00.00.22 |
How to print Spring Hanger Selection report in AutoPIPE?
See procedure below.
Using AutoPIPE CONNECT 11.00.00.22 and higher
Step #1:
Select Analysis> Hanger Selection
Step #2:
Select checkbox next to "Show hanger report"
Step #3:
After running the analysis the report will be displayed after.
