| Version(s): | ALL | ||
| Area: | Hanger Selection | ||
Hanger design - do we attach a sign to the cold load ie. - or + ?
Depending on the movement whether it should be + or - ?
No, at no time should you enter a -ve value into the spring hanger dialog:
