| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Modeling |
| Date Logged & Current Version | June. 2017 11.00.00.22 |
Reduction (W) factors. AutoPIPE does not let me have a reduced weld W factor when the quality E factor is equal to 1. The quality factor (E) is based on 100% radiograph of the initial weld. The reduction faction (W) is based on the weld joint strength over time. These 2 factors should be programmed independent of each other, not dependent on each other. Please let me know why these 2 weld factors cannot be independent in AutoPIPE
Please open the Pipe properties dialog and press Help button.
Select the hyper link for "Long Weld W Fact"
On this page, half way down is a Note:
See help for more details on this setting.
