| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Graphic | ||
| Date Logged & Current Version | June. 2016 10.01.00.09 | ||
How to change the scale size of the components in AutoPIPE (supports, valves, anchors, etc..)?
The size of components are controlled by 2 settings:
1. Pipe properties OD setting
2. View> Settings> Scale Factor Tab, Valid scale factors = 0 to 10
Default size:
Pipe properties increased from 6" to 12":
Scale factor increased from 1 to 3:
The scale size of components in an AutoPIPE model can be change to suit a users preference.
