| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Graphics | ||
| Date Logged & Current Version | Feb. 2015 09.06.01.10 | ||
Input grids indicate items in model, but screen is blank, how to view the model?
There are a few suggestions to finding the model graphics
Under View> Hide Components> be sure that all check-boxes are blank as shown below:
Then perform the following command, View> Show all components.
Does the model show in the graphics window? If not continue to option #2.
On the Segment tab of the input grid, find column named "Show", be sure that all check-boxes in this column are checked Enabled (i.e. checked ON) as shown below:
If not enable all the check-boxes. Does the model show in the graphics window? If not continue to option #3.
In order to reset the graphics window, place the mouse on the corner of the AutoPIPE application window and drag resizing the application wind larger or smaller. The will cause the graphics to reset.
Does the model show in the graphics window? If not continue to option #4.
On the toolbars press the icon to zoom "View all points"
Does the model show in the graphics window? If not continue to option #5.
Look at the lower left corner of the screen, does the Axis icon appear or not?
Perform the following procedure:
a. Change number of view ports to 4
b. Select Top Left viewport and then pres the "View all points" icon.
c. If the model graphics appears, re-select "Single Viewport" toolbar button. Should now see the model graphics. Save the model as a different model name and continue using the application.
