| Version(s): | ALL | ||
| Area: | graphic | ||
User is utilizing GUI function for support loads If two supports are in same location, how does he access the second one graphically?
For review on of support loads best to use, Tools> Results Grids> Support where the user has the many more options of reviewing / interagating the results.
Or if they prefer using a very restrictive method of review the results, Results> Supports> just zoom into the location and left click the mouse on any support. The support will turn Red and the results data will be displayed int he floating dialog screen
Select zoom as needed to select the next support, again the currect slected support will turn red and the data will be available in a floating dialog screen (see below):
