06. (09) "Bend" - Input grid tab in AutoPIPE
Comments, Questions, and Answers about the Bend tab on AutoPIPE input grids
Item #1
Is it possible to see the value of the Flexibility Factor that Autopipe uses for a particular bend? Instead of the value that Autopipe calculates with I can only see the word "Automatic".
Answer:
Short answer: Yes.
Create a model input list report with the Bend sub report truned ON.
Steps for AutoPIPE V8i 09.06.01.xx and lower:
1. Select Tools> Model input Listing
2. Enable the Bend Check box (i.e. Checked ON) and press OK button.
3. A report is created and automatically displayed, see the Flexibility column in the report for calculated values.:
Input grids
