| Product(s): | WinNOZL | ||
| Version(s): | V8i | ||
| Area: | Installation | ||
Version 08.11.00.01
Build Tpe: Select Release Product
Operating Systems: Microsoft Windows (see System Requirements for specific details)
Language: English
Date: 05-22-2009
Bentley® WinNOZL is a stand-alone, engineering application used for calculating local stresses at nozzle/vessel junctions, trunnion attachment points, clip connections and lug attachments on the vessel shell. Based on well-known engineering design standards like WRC, KHK, API and PD, WinNOZL helps engineers and designers quickly determine whether or not the wall of a pressure vessel, exchanger or tank can withstand piping loads on the nozzle or at clip and lug connections.
•Applications Included in This Workgroup
•System Requirements
•Product Download and Installation
•Bentley SELECT Server XM Licensing
•Documentation
•Issues Fixed
WinNOZL is installed from one executable. The license file received from Bentley BAC will initiate your specific application.
WinNOZL - The standard configuration of WinNOZL includes these features:
¦ Internationally recognized design codes:
WRC 107, WRC 297, BS PD5500, API 650 and KHK 1 & 2
¦ Extensive material libraries for ASME VIII Div I, Div II and PD5500, 1998 ASME VIII code case 2290, 2000 ASME I, III & IV, PD5500/enquiry case 91, ASME materials to the PD5500, JIS, KHK
¦ JIS and DIN pipe property library
¦ Shell types: cylindrical, conical, spherical, semielliptical, and torispherical
¦ Nozzle attachment types: hollow or solid round, hollow or solid rectangular
¦ Shell deflections, rotations and stiffness values are calculated for all shell types per PD5500 Annex G for longitudinal, circumferential and radial loadings
Important Note: This Bentley WinNOZL V8i SELECT Release (3.1.0) is only intended to resolve Bentley WinNOZL 3.0.0.7 issues and update to SELECT Server XM Licensing. The following prerequisites are required to run each of the modules included within the application:
Processor |
Intel Pentium 486 or higher |
Operating Systems |
Web Browser |
Microsoft Internet Explorer 6 or greater MDAC 2.5 (or later), DCOM 95 (Win95 only) |
Memory |
32MB |
Hard Disk |
21 MB minimum free hard disk space |
Graphics Card |
Any industry-standard video card |
Other Pre-requisites |
IEG Security (free download at Bentley SELECT) |
PDF Reader |
Adobe® Acrobat Reader 8.0 or greater |
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
To download the products, create a MySELECT CD or to complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles you will need to obtain the name of your Site Administrator from the Bentley website at SELECTservices Online at http://selectservices.bentley.com . Select MySupport Account / Permissions. Clicking on the List SELECTservices Administration button will access the Site Administrator at your company enabling you to request that the appropriate permissions be added to your profile.
With the appropriate privileges you can obtain the software as an electronic file from Web Downloads or the products may be ordered on a personal CD through MySELECT CD. Once you have installed the desired product you will need to complete the product authorization process by obtaining a license file from Bentley.
Network Considerations
Network drives are not supported for the software and data files.
WinNOZL software must be installed on a local client workstation.
WinNOZLdata files (*.NOZ) must have full read/write access and can only be accessed from a local client workstation.
WinNOZL will be licensed based on availability of license in License Management Tool . For more details on licensing refer to readme file or online help.
Program Help:
Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Documentation for applications is provided online in the CHM format. These files are accessible from the Help Menu and can be browsed, searched, or printed.
Quick Start guide is a PDF which can be browsed, searched, or printed with the Adobe Acrobat Reader.
Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
Bentley WinNOZL V8i SELECT Release (8.11.0) contains modifications necessary to correct Bentley WinNOZL 03.00.00.07 software on a workstation. Please refer to Tracker for more information on the following issue(s):
Note: the number in parentheses is the PVCS tracker record.
Id |
Title |
(2439) |
Changing design codes with a user defined pad thickness can lead to a crash |
(2446) |
Authorized license is not released when a different design code is selected |
(2447) |
Model may not open properly if the nozzle schedule is undefined |
(2628) |
Allowable stresses in the one page summary report may be incorrect when sorted |
(2717) |
Changing from a round to rectangular nozzle may cause incorrect warning message |
(2736) |
Incorrect processing of fillet radius on Factors Tab using non-English units |
(2755) |
Enter negative factors for user load combinations crashes the program |
(2757) |
Importing AutoPIPE loads may blank all existing user defined load combinations |
(2760) |
Enter design or ambient temp sets shell/nozzle/pad allowables to same value |
(2761) |
Entering user defined design and ambient allowable stresses should display blue |
(2763) |
Entering a single decimal point or comma crashes the program |
(2776) |
Analyze a model may give incorrect results with blank load combinations |
(2826) |
The material library may not be seen when selected code is PD5500 |
(2827) |
Zero design and ambient stress for some materials in PD5500 material library |
(2849) |
Delete all grid cells in Add User combination dialog will crash the program |
(2887) |
API650 SG value using SI units is incorrectly displayed in the input listing |
(2888) |
Some API650 parameters are incorrect in the input listing for SI units |
(2889) |
The material library name is not shown on the input listing |
(2905) |
Load cases grid may not be formatted correctly on the load combinations dialog |
(2906) |
Cancel from material dialog does not restore API650 Hydrostatic stress |
(2908) |
API650 Nomograms for user defined combinations are incorrect |
(2910) |
Some of the labels on the API650 Nomogram are incorrect |
(2912) |
Print all detailed stress combinations report option does not work for API650 |
(2913) |
The API650 summary load percentage value may be incorrect |
(2923) |
DIN and JIS pipe properties may be incorrectly set |
(2933) |
Blank page may be printed after input loads |
(2935) |
Yield stress (ambient and design) is not printed in the input report |
(2940) |
"Print all detailed stress combinations" report option should be disabled |
(2965) |
The 'question mark' help button on the detailed stress screen is not working |
(2982) |
If nozzle size or thickness = 0 then analyze may crash the program |
(3030) |
Single or double click on the summary stress screen may crash the program |
(3319) |
Older models with 'solid pipe' nozzles may get switched to 'hollow pipe' |
(3321) |
User combinations with thermal loads will have incorrect allowable stress |
(3349) |
NOZ file does not load when associated with WinNozl executable |
(3356) |
Do not prompt to save the model on exiting the program |
(3428) |
Display detailed stresses or print reports keeps showing "Re-analyze" message |
(3505) |
1-page summary may not highlight all overstress load combinations |
(4018) |
API650 summary combinations exceeding the limits do not display RED |
(4033) |
The XYZ axis is shown incorrectly on the API650 report |
(4170) |
WRC107 warning message may not be reported for the Pad |
(4735) |
Incorrect loads may be used in the stress calculations |
(4792) |
KHK2 combination GMOVE with negative values in the PXF file may not be imported |
(5127) |
User combinations may prevent the 1-page report from being printed |
(5138) |
Membrane & Bending Stress Factors shown as 1 in Factor tab & input report |
(5146) |
Importing non-code loads from AutoPIPE may hang program |
(5392) |
Some JIS schedules are incorrect |
(5436) |
Factors and Loads Tabs & some fields may not be initialized correctly on startup |
(5761) |
Local coordinate system is incorrect when importing loads with X or Z vertical |
(6353) |
"Calculate Pad Dimensions" option always resets the pad thickness = 3mm or 1/8" |
(7070) |
Allowable loads maybe zero when running the KHK code |
(7087) |
Metric hillside offset is not displayed correctly on the geometry sketch |
(7223) |
Some WRC107 rectangular nozzle configurations give very high stresses |
(7894) |
The pressure tolerance is too coarse to calculate allowable loads |
(7896) |
Cannot import loads from AutoPIPE v9.1 |
Bentley AutoPIPE Nozzle Release Notes
