| Product(s): | AutoPIPE Nozzle | ||
| Version(s): | V8i | ||
| Area: | Release Notes | ||
Thu, 13 Oct 2011 23:46:00 EDT
This release fixes 6 issues including:
- Combinations with user defined loads are not reported in the grid
- Stresses are misprinted in the output report
Following is a list of new features in the Bentley AutoPIPE Nozzle V8i:
Update KHK code to 2006
Update KHK material library to 2003
Update JIS material library in JIS B 8265
Average membrane and M+B allowables forDiv 2 allowable
Filter material list according to selected design code
Provide a check box to include or exclude the 1.2 increase factor for occasional loads
Provide a check box to use averaged or non-averaged values for calculation of stress allowables e.g. evaluating cyclic loads for fatigue.
Include different nozzle attachment types
Allow importing loads from AutoPIPE v9.1
Change apnozzle.map file format to CSV to support long filenames
Consolidate AutoPIPE Nozzle design code licenses into one license
Bentley AutoPIPE Nozzle Release Notes
