| Product(s): | AutoPIPE Nozzle | ||
| Version(s): | V8i | ||
| Area: | Release notes | ||
Version 08.11.08.22
Operating Systems: Microsoft Windows (see System Requirements for specific details)
Language: English
Date: 3/7/2014
Bentley® AutoPIPE Nozzle is a stand-alone, engineering application used for calculating local stresses at nozzle/vessel junctions, trunnion attachment points, clip connections and lug attachments on the vessel shell. Based on well-known engineering design standards like WRC, KHK, API and PD, AutoPIPE Nozzle helps engineers and designers quickly determine whether or not the wall of a pressure vessel, exchanger or tank can withstand piping loads on the nozzle or at clip and lug connections.
Program Features
Design Code Years
System Requirements
Product Download and Installation
Bentley SELECT Server Licensing
Documentation
New Features
The standard configuration of program includes these features:
Internationally recognized design codes: WRC 107, WRC 297, BS PD5500, API 650 and KHK 1 & 2
Extensive material libraries for ASME VIII Div I, Div II and PD5500, 1998 ASME VIII code case 2290, 2000 ASME I, III & IV, ASME 2009 VIII Div 1, VIII Div 2 & Sect III, PD5500/enquiry case 91, ASME materials to the PD5500, JIS, KHK
JIS and DIN pipe property library
Shell types: cylindrical, conical, spherical, semielliptical, and torispherical
Nozzle attachment types: hollow or solid round, hollow or solid rectangular
Shell deflections, rotations and stiffness values are calculated for all shell types per PD5500 Annex G for longitudinal, circumferential and radial loadings
For ASME Design Codes following code years are available:
ASME Div 1:
< 2001
>= 2001 3S
>= 2001 2Fy (No Creep)
ASME Div 2:
< 2001 (No Creep)
2001 < 2007 (No Creep)
>= 2007 (No Creep)
Important Note: The following prerequisites are required to run the application:
Processor |
Intel Pentium IV or higher |
Operating Systems |
Microsoft Windows XP Professional SP3 or later OR |
Web Browser |
Microsoft Internet Explorer 6 or greater |
Memory |
256MB |
Hard Disk |
36 MB minimum free hard disk space |
Graphics Card |
Any industry-standard video card |
Other Pre-requisites |
IEG Security (free download at Bentley SELECT) |
PDF Reader |
Adobe® Acrobat Reader 8.0 or greater |
Before you install any software, you should confirm that you have adequate hardware and software capabilities to install and use the product.
AutoPIPE Nozzle is distributed as part of AutoPIPE program. Please refer to product download and installation section of the AutoPIPE readme file.
Network Considerations
Network drives are not supported for the software and data files.
AutoPIPE Nozzle software must be installed on a local client workstation.
AutoPIPE Nozzle data files (*.NOZ) must have full read/write access and can only be accessed from a local client workstation.
AutoPIPE Nozzle will be licensed based on availability of either AutoPIPE Advanced or AutoPIPE Nuclear license. For more details on AutoPIPE licensing refer to AutoPIPE readme file or AutoPIPE online help.
Program Help:
Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Documentation for AutoPIPE Nozzle applications is provided online in the CHM format. These files are accessible from the Help Menu and can be browsed, searched, or printed.
AutoPIPE Nozzle Quick Start guide is a PDF which can be browsed, searched, or printed with the Adobe Acrobat Reader.
Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
Following is a list of new features in the Bentley AutoPIPE Nozzle V8i:
AutoPIPE Nozzle ASME Code 2007 and database updates
Update KHK code to 2006
Update KHK material library to 2003
Update JIS material library in JIS B 8265
Average membrane and M+B allowables forDiv 2 allowable
Filter material list according to selected design code
Provide a check box to include or exclude the 1.2 increase factor for occasional loads
Provide a check box to use averaged or non-averaged values for calculation of stress allowables e.g. evaluating cyclic loads for fatigue.
Include different nozzle attachment types
Allow importing loads from AutoPIPE v9.1
Change apnozzle.map file format to CSV to support long filenames
Consolidate AutoPIPE Nozzle design code licenses into one license
Bentley AutoPIPE Nozzle Release Notes
